AnsweredAssumed Answered
10.5.1 License manager and Direct Access
Question asked by jplattner on Apr 27, 2018
Latest reply on Aug 14, 2018 by daniel_l_svevia
Has anyone had success using "Direct Access" and ArcMap 10.5.1?
We are in the middle of upgrading from 10.3.1 to 10.5.1. For whatever reason we get a license manager error when trying to use ArcMap 10.5.1 via a Direct Access connection. Our ArcMap installs of 10.3.1 are able to connect to this same license manager with no problems via Direct Access. It's so weird!
If we use ArcMap 10.5.1 using our regular ethernet cable or internal wifi we connect to the license manager no problem.
We contacted tech support, and so far they've told us that the license manager needs to be on the same sub-net as our computers. We aren't sure what that means, and why 10.3.1 would still work, while 10.5.1 does not.
They also said that IPv6 is not compatible with License Manager, though in our case it has been disabled, so our network staff says this shouldn't be an issue.
I've read this discussion,  ArcGIS 10.4 license trough Direct Access/ IPv6  but our network staff again says the fixes they describe don't apply to our situation.
If you are able to use direct access, I'd appreciate it if you could let me know.  I'm curious to find out what's different about your setup, compared with ours.
Thank you internet!
Outcomes
