Attribute table doesn't display
27756
11
04-25-2018 05:20 AM
MarieBabona
I am trying to open my attribute table from Arcmap 10.5, but this one can't open and a get this message ''ArcMap 10.5 will not display the Attribute Table dialog box''. I tried this option Problem: ArcMap will not display the Attribute Table dialog box for a layer, yet it's not working. Can someone help me to fix this out. Thanks
JakeSkinner
Esri Esteemed Contributor
I would try renaming the Normal.mxt.  To do this:
  1. Close ArcMap
  2. Open File Explorer and navigate to C:\Users\<user>\AppData\Roaming\ESRI\Desktop10.5\ArcMap\Templates
  3. Rename the Normal.mxt to Normal_Old.mxt
  4. Restart ArcMap and try to open the attribute table
JakeSkinner
Hi Marie,
What type of data are you working with (i.e. shapefile, File Geodatabase feature class, Enterprise Geodatabase feature class)?  Can you try importing the data into a new File Geodatabase and then see if you can open the attribute table?
MarieBabona
Hello Jake,
Thanks for your help. I'm using a shapefile, I've import the shapefile into a File Geodatabase but still the attribute table doesn't display
JakeSkinner
Can you send a screen shot of ArcMap?
MarieBabona
JakeSkinner
  1. Close ArcMap
ConnieWong
Thank you!  It works for me.  122320
MarieBabona
Thanks  a lot Jake! It was a little bit tricky to find the AppData on computer but I definitely found it and It worked out
CurtHarvey
New Contributor III
Having to kill the normal.mxt is an infuriating fix. Having  to re-create my customized interface is a total hassle. At 10.6 should this still really be happening? Of course not!
EvanJackson3
ArcGIS 10.7 and counting... This is still the solution! Unbelievable. ESRI please fix by including an 'Attribute Table" view open/close option in 'Customise' or Window tab? It's frustrating to accidently lose an attribute table, then have to reset the .mxt and lose all settings to get it back.
