JSON Web Service appear on Map with point graphics , when click on point show the data into info temple.
831
04-22-2018 11:50 PM
AnujKumar5
I have JSON Web Service which need to show on Dynamic Map with point Graphics so, when i click on point graphics which are appear on Map it should be show data of Json Service into Info template. I have define all thing in code as per my knowledge and i can see the json data at the time of debugging but when i call it i get error length property . am sharing code any one help predicated.
My code:-
 <script src="https://js.arcgis.com/3.23/"></script>
      <script src="http://ajax.googleapis.com/ajax/libs/jquery/1.7.1/jquery.min.js" type="text/javascript"></script>
      <script>    var dojoConfig = {      parseOnLoad: true    };  </script>
   <script>
 var map; var mis_rec = [];
 var mis_recPoly = []; var gis_rec = []; var attributes = [],point,pointData;
  require(["esri/map",
      "esri/layers/ArcGISDynamicMapServiceLayer",
         "esri/layers/ImageParameters",
           "esri/InfoTemplate",
            "dojo/dom",
             "dojo/on",
             "dojo/dom-class",
             "dojo/_base/json",
             "esri/config",
           "dojo/_base/lang",
           "esri/request",
         "esri/geometry/Point",
 "esri/symbols/SimpleMarkerSymbol",
         "esri/graphic", "esri/layers/GraphicsLayer",
            "dojo/domReady!" ],
 function (Map, ArcGISDynamicMapServiceLayer,
               ImageParameters,InfoTemplate, dom,
                  on, domClass, dojoJson, esriConfig,
          esriRequestlang,esriRequest,Point, SimpleMarkerSymbol,
           Grahpic, GraphicsLayer) {
  esriConfig.defaults.io.corsEnabledServers.push("ncog.gov.in");
      map = new Map("mapDiv", {
        sliderOrientation : "horizontal"
          var imageParameters = new ImageParameters();
         imageParameters.format = "jpeg"; //set the image type to PNG24, note default is PNG8.
        //Takes a URL to a non cached map service.
         var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("http://10.1.31.13/arcgis/rest/services/Thematic_Atlas/DVA/MapServer",
             "opacity" : 1,
          "imageParameters" : imageParameters
          var polygraphlayer = new GraphicsLayer();
          map.addLayers([dynamicMapServiceLayer,polygraphlayer]);
       dojo.connect(map,"onLoad",_ajaxcall);
               function _ajaxcall(gis_rec) {
        //document.getElementById("bodyloadimg").style.display = "block";
        $.ajax({
             type: 'GET',
          url: "https://ncog.gov.in/JSON_webservice/get_food_data?code=7654",
          crossDomain: true,
            success: function (dat) {
                 mis_rec = [];
              mis_recPoly = [];
                      point = new Point();
                  pointData = dat.point;
                    for (var j = 0; j < pointData.length; j++) {
                     var attributes = [];
                for (var i = 0; i < pointData.children.length; i++) {
                     var chk = pointData.children[1].nodeName + "=" + pointData.children[1].innerHTML;
                        attributes[pointData.children.nodeName] = pointData.children.innerHTML;
                     mis_rec.push(attributes);
                }                // var polygonData = dat.getElementsByTagName('polygon');
                   gis_mis1(mis_rec);
             error: function (err) {
                //document.getElementById("bodyloadimg").style.display = "none";
             alert(err.statusText);             }
  function gis_mis1(mis_rec) {
               clearGraphics();
             for (var i = 0; i < mis_rec.length; i++) {
                 if (mis_rec.log && mis_rec.lat) {
                     var pt = new Point(Number(mis_rec.log), Number(mis_rec.lat), new SpatialReference({ wkid: 4326 }));
                 // if (mis_rec[name]>0) {
                       var markersymbol = new PictureMarkerSymbol('images/hos.png', 18, 22);
                       var attr = mis_rec;
             //{ "Activity": activity.activityName, "Activity Code": activity.activityCode };
                    var content = '<table>';
                    content += "<tr><td><b>District Id</td></b>" + "<td><b>: </b></td><td> ${dist_id}</td></tr>";
                    content += "<tr><td><b>Email Nodal</td></b>" + "<td><b>: </b></td><td> ${email_nodal}</td></tr>";
                    content += "<tr><td><b>State Id</td></b>" + "<td><b>: </b></td><td> ${st_id}</td></tr>";
                   content += "<tr><td><b>Total Land</td></b>" + "<td><b>: </b></td><td> ${total_land}</td></tr>";
                    content += "<tr><td><b>Industrial Name</td></b>" + "<td><b>: </b></td><td> ${industrial_name}</td></tr>";
                     content += "<tr><td><b>Land Area</td></b>" + "<td><b>: </b></td><td> ${land_area}</td></tr>";
                   content += "<tr><td><b>Nodal Name</td></b>" + "<td><b>: </b></td><td> ${name_nodal}</td></tr>";
                    content += "<tr><td><b>EHR</td></b>" + "<td><b>: </b></td><td> ${EHR}</td></tr>";
                content += "<tr><td><b>Id</td></b>" + "<td><b>: </b></td><td> ${id}</td></tr>";
              content += "<tr><td><b>Category</td></b>" + "<td><b>: </b></td><td> ${category}</td></tr>";
                   content += '</table>';
         var infoTemplate = new InfoTemplate('Land Info', content);
                  polygraphlayer.add(new Graphic(pt, markersymbol, attr, infoTemplate));
  var gl = new GraphicsLayer({ id: "st_id" });
          map.addLayer(gl);
RobertScheitlin__GISP
Anuj,
   Here is your code modified to work. I did not have access to some things in your code so I adjusted because of that. Your biggest issue was you were not specifying the dataType of the ajax call and then you were parsing it wrong.
<!DOCTYPE html>
<html>
<head>
  <title>Create web map from id</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.24/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.24/esri/css/esri.css">
  <style>
      html, body, #mapDiv {
        height: 100%;
        margin: 0;
        padding: 0;
    </style>
  <script>
    var dojoConfig = {
      parseOnLoad: true
  </script>
  <script>
    var map;
    var mis_rec = [];
    var gis_rec = [];
      point, pointData;
        "dojo/dom",
        "dojo/on",
        "dojo/dom-class",
        "esri/config",
        "dojo/_base/lang",
        "esri/request",
        "esri/SpatialReference",
        "esri/symbols/PictureMarkerSymbol",
        "esri/graphic",
        "dojo/domReady!"
      function(Map, ArcGISDynamicMapServiceLayer,
        ImageParameters, InfoTemplate, dom,
        on, domClass, esriConfig,
        esriRequestlang, esriRequest, SpatialReference, Point, PictureMarkerSymbol,
        Graphic, GraphicsLayer) {
        //esriConfig.defaults.io.corsEnabledServers.push("ncog.gov.in");
          basemap: "topo", //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
          center: [75.0444, 15.3563], // longitude, latitude
          zoom: 5
        var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("http://10.1.31.13/arcgis/rest/services/Thematic_Atlas/DVA/MapServer", {
          "opacity": 1,
          "imageParameters": imageParameters
        map.addLayers([dynamicMapServiceLayer, polygraphlayer]);
        dojo.connect(map, "onLoad", _ajaxcall);
        _ajaxcall();
          $.ajax({
            type: 'GET',
            dataType: 'json',
            crossDomain: true,
            success: function(dat) {
              gis_mis1(dat);
            error: function(err) {
          //clearGraphics();
            var rec = mis_rec[i];
            if (rec.lon && rec.lat) {
              var pt = new Point(Number(mis_rec[i].lon), Number(mis_rec[i].lat), new SpatialReference({
                wkid: 4326
              var markersymbol = new PictureMarkerSymbol("https://js.arcgis.com/3.15/esri/dijit/images/Directions/greenPoint.png", 21, 29);
              var attr = mis_rec[i];
        map.addLayer(gl);
  </script>
</head>
<body>
  <div id="mapDiv"></div>
</body>
</html>
Anuj,
<!DOCTYPE html>
<html>
<head>
  <style>
        height: 100%;
        margin: 0;
        padding: 0;
    </style>
  <script>
    var dojoConfig = {
      parseOnLoad: true
  </script>
  <script>
    var map;
    var mis_rec = [];
    var gis_rec = [];
      point, pointData;
        "dojo/dom",
        "dojo/on",
        "dojo/dom-class",
        "esri/config",
        "dojo/_base/lang",
        "esri/request",
        "esri/graphic",
        "dojo/domReady!"
          zoom: 5
          "opacity": 1,
        _ajaxcall();
          $.ajax({
            type: 'GET',
            dataType: 'json',
            crossDomain: true,
              gis_mis1(dat);
          //clearGraphics();
                wkid: 4326
        map.addLayer(gl);
  </script>
</head>
<body>
</body>
</html>
AnujKumar5
Thank you Robert..!
AnujKumar5
Robert,
I have an issue that how to remove this graphic from map on checkbox event ,
it try to map.graphics.clear() function  but it's won't work.
