Using percentages as threshold in Indicator and Gauge
734
04-19-2018 10:41 AM
AdamRepsher
Occasional Contributor III
I am having trouble using the Indicator - well, most of the data-driven elements when wanting to use a certain percentage of....  Heck, I have trouble even describing it.
This is in Portal at 10.6:
I have a map service that contains a test grid, basically squares that cover Pennsylvania.  Each grid square has a value for County (County Name that the grid square falls mostly in) and a value for Result (Pass, Fail).  I need to create an Indicator or Gauge that shows the Percentage of Passes in GREEN if >= 95% of the total number of tests are 'Pass', and the same in RED if < 95% of the total number of tests are 'Fail'.  I don't really need count numbers.  I will then let a category selector filter the element for either specific counties or "ALL" counties.
Has anyone accomplished this type of configuration?  I feel that these are probably not the tools I'm looking for, or the data format i'm looking for!
--Adam
