AnsweredAssumed Answered
Recent Custom Widget problem
Question asked by deleted-user-lcmcZbtxpmT3 on Apr 18, 2018
Latest reply on Apr 18, 2018 by deleted-user-lcmcZbtxpmT3
When I compile the Recenter widget from your online example- using tsc 2.8- it creates a slightly different .js file and does not show custom widget in right corner of web page- if I change to use the source code on the site it works-
(but I cannot compile so no changes)
https://developers.arcgis.com/javascript/latest/sample-code/widgets-custom-recenter/index.html
The new compilation produces an error also
From website (works)
define(["require", "exports", "esri/core/tsSupport/declareExtendsHelper", "esri/core/tsSupport/decorateHelper", "esri/core/accessorSupport/decorators", "esri/widgets/Widget", "esri/core/watchUtils", "esri/widgets/support/widget"], function (require, exports, __extends, __decorate, decorators_1, Widget, watchUtils, widget_1) {
Using tsc 2.8 (doesn’t work)
define("Recenter", ["require", "exports", "esri/core/tsSupport/declareExtendsHelper", "esri/core/tsSupport/decorateHelper", "esri/core/accessorSupport/decorators", "esri/widgets/Widget", "esri/core/watchUtils", "esri/widgets/support/widget"], function (require, exports, __extends, __decorate, decorators_1, Widget, watchUtils, widget_1) {
Recenter.prototype._defaultCenter = function () {
            this.view.goTo(this.initialCenter);
        return Recenter;
    }(decorators_1.declared(Widget)));
    __decorate([
        decorators_1.property(),
        widget_1.renderable()
    ], Recenter.prototype, "view", void 0);
    __decorate([
    ], Recenter.prototype, "initialCenter", void 0);
    __decorate([
    ], Recenter.prototype, "state", void 0);
    Recenter = __decorate([
        decorators_1.subclass("esri.widgets.Recenter")
    ], Recenter);
    return Recenter;
//# sourceMappingURL=Recenter.js.map
Using tic 2.8 (doesn’t work)
        __decorate([
        __decorate([
        __decorate([
        ], Recenter);
        return Recenter;
    return Recenter;
Any help would be appreciated- as this is the guide to further development I would like it to compile correctly.
Outcomes
