AnsweredAssumed Answered
.Net Runtime 100.2 Unable to Create Attributes with an Object
Question asked by FDM_Jim on Apr 17, 2018
Latest reply on Apr 17, 2018 by FDM_Jim
In 10.2.7 I was able to create a Graphic object and assign attributes to it. Now at 100.2 the same code doesn't work and I've tried multiple ways to resolve the problem:
  1. Create a Graphic with a constructor containing an Attribute dictionary
  2. Create a Graphic and assign the attributes after the fact
The breaking point seems to be the assignment of an object and if I omit the object the Attributes \ Graphic can be created. I need some input on this. Below is my code examples of what doesn't work:
Failing Example #1
//create a basic map details item object to pass in
var mapDetails = new MapDetailsItem
Id = dataItem.Id.NativeValue, //this is an int
ProfileId = dataItem.ProfileId.NativeValue, //this is an int
HasLayout = dataItem.HasLayout //this is an bool
var location = new Esri.ArcGISRuntime.Geometry.MapPoint(dataItem.Longitude, dataItem.Latitude, new SpatialReference(SpatialReferences.Wgs84.Wkid));
Graphic result = new Graphic(location);
if (result != null)
result.Attributes["ID"] = dataItem.Id.NativeValue;
result.Attributes["Description"] = dataItem.Description;
result.Attributes["MapDetailsItem"] = mapDetails; //this item will break and throw an exception
Failing Example #2
var graphicAttributes = new Dictionary<string, object>
{"ID", dataItem.Id.NativeValue},
{"Description", dataItem.Description},
{"MapDetailsItem", mapDetails}
Graphic result = new Graphic(location,graphicAttributes);
Here is the error which I receive:
Outcomes
