ArcGIS Explorer - not seeing mmpk (Android)
1047
04-16-2018 11:11 AM
MichaelKnapp
Hi there -
I'm experimenting with creating MMPKs (via ArcGIS Pro 2.1) that can be used offline by some field personnel who will be out of mobile data range. We are looking for a non-organizational account solution for offline maps.
I'm testing with the Android app version 10.2.10 build 1335.
Using the Android app, I don't seem to be able to find the test mmpk I've created. I've made it publicly available at: http://bss.maps.arcgis.com/home/item.html?id=38ee1e3d2bc0435bbeaf397f845b214d
When I do a generic search for all MMPKs via Explorer, I do find some, just not mine.
Am I missing something obvious (I suspect so).
I've been using this as my guidance: https://community.esri.com/groups/explorer-for-arcgis/blog/2018/01/22/make-an-offline-map-with-arcgi...
Note: I am creating the mmpk without a basemap and the vector data source is a gdb.
MarkBockenhauer
Michael,
You will need the beta version of Explorer for ArcGIS to use Mobile Map Packages.
The version you are using does not have support for them.
check out this information about getting the beta version.
https://community.esri.com/thread/196225-android-explorer-beta-release-signup-and-install-informatio...
Mark
MarkBockenhauer
Michael,
Mark
MichaelKnapp
Great....thanks for the reply Mark!
MarkBockenhauer
Explorer for ArcGIS with Mobile Map Package support is available in the Google Play Store now.
