HEC-GeoRAS and HEC-GeoHMS for ArcGIS 10.6
16030
7
04-15-2018 12:04 AM
ErstayudhaNurrizqi1
Hello! I know there is a version of HEC-GeoRAS and HEC-GeoHMS for ArcGIS 10.5. I need these two plugins for ArcGIS 10.6. Does anybody know where I can find such versions?
I searched in this link, but for version 10.6 doesnt exist yet. Do I have to downgrade the arcgis version?
http://downloads.esri.com/archydro/
RodrigoValdes
Hello, did you figure this out?... thank you !
JonathanMusser
AashaKhadka
Hi Jonathan,
I am trying to install Hec GeoRAS 10.6 but it ask for the username and password. Do you have any idea about it?
Thankyou
ErstayudhaNurrizqi1
Thanks for information. Hecgeoras for 10.6 has been uploaded on the yellow.esri.com website, only hecgeohms has not yet appeared.
NickWeil
New Contributor III
Hi Erstayudha Nurrizqi, I am also looking for hecgeohms for 10.6. Have you had any luck finding out when it will be available?
TungNg
New Contributor III
The most updated version of HEC-GeoHMS (10.5.0.7) was published on Aug 30, 2017. I highly doubt there will be future versions developed for HEC-GeoHMS. Whoever wants to use it would have to stick with ArcGIS 10.5 assuming all the tools work as intended.
There is a similar question on Research Gate where posters had to downgrade to older versions
I am able to run Preprocessing, Project Setup, and Basin Pro When I run characteristics or parameter...
If you decide to downgrade, make sure to use "Save a copy" option so that you can open the MXD files with the older versions of ArcGIS
Will ArcGIS 10.6 mxd open in 10.5? - Geographic Information Systems Stack Exchange
Otherwise you'll have to use the MXD Doctor utility
Using the MXD Doctor utility—Help | ArcGIS Desktop
NestorGarro_Espinoza
HELLO EVERYBODY, TODAY  19/11/2019, YOU CAN DOWNLOAD HEC-GeoHMS for ArcGIS 10.6 IN: yellow.esri.com - /ArcHydro/HECGeoHMS/Setup10_6/
AND HEC-GeoRAS for ArcGIS 10.6yellow.esri.com - /ArcHydro/HecGeoRAS/10.6/
