lat&long
1011
12
04-16-2018 01:32 AM
GERTISEDO
New Contributor III
hi
I have table with point on UTM system  and i want to save on lat&long system
what can i do for more attach file...  (help with image for save on lat&long)...
XanderBakker
Esri Esteemed Contributor
First of all you need to know what UTM zone the coordinates correspond to:
source: https://i.stack.imgur.com/8f5Fe.jpg
Depending the software that you have available there are many options to translate the coordinates to Lat Lon. Another question is in what format you you want the result (another text file or a point featureclass)?
GERTISEDO
New Contributor III
yes of course i know its 34T but i want to save on lat&log ect...
i am ok  UTM but on lat and long ei have problem ...
XanderBakker
And what about the software that you have access to? Desktop (ArcMap or ArcGIS Pro) or perhaps ArcGIS Onlinel? This is important to know to be able to provide a solution that will work for you.
GERTISEDO
New Contributor III
arcmap 10.4.1
XanderBakker
You will first have to change your text file so that ArcMap can understand it by adding a header:
The add it to ArcMap, which will interpret it as a table:
Use the Add XY events option to create point features with the appropriate coordinate system:
Followed by selecting the right fields:
and define the coordinate system (not sure if this the correct one in my screenshot below)
When you have the point events you can use the project tool to create a physical output featureclass with the WGS 1984 geographic coordinates:
and add coordinates:
to obtain the decimal degrees of the geographic coordinates as attributes in the featureclass:
GERTISEDO
New Contributor III
hi Xander
perfect job but i want to see  all   field of label on workspace and what can i do
please attach photo
XanderBakker
From your screen shot you are using the Field Calculator and I see more fields than you have in the file you shared. My first step was to define a proper header:
This will result in ID, X, Y and Z fields. What schema of data are you using and what process are you using the Field Calculator for (I did not use it in my steps)?
GERTISEDO
New Contributor III
ok  i want see all ID,X,Y,Z on workspace and i need your help ....what can i do ....for this
and make final gird ...
RobertBorchert
Frequent Contributor III
Quick and simple.
Create Columns for X and Y make them double.
then in ArcMap right click on the column and calculate geometry.
Use the coordinate system of the features you want in lat long.
but in the drop down menu select Decimal Degrees.  this will create XY values for your UTM 34T
Or to make it even more simply use the tool  Add XY Coordinates.
