Trying to Convert Points to a Polyline
3906
7
04-13-2018 12:20 PM
MATTHEWTOMITZ
Hello everyone.  I have an issue with converting points into a polyline.  I have trail lines, and elevation points.  I am trying to combine the two so that I have a nice polyline with slope values representing gentle-moderate-steep.
When I run Point-to-Polyline, I get weird zigzag lines that DO go from point to point, but also go out of order.  I've run XY to line, but only get one XY value for the whole line.  I tried Split Line at Point, which made a polyline of only two segments (when I'm looking for a couple hundred segments).
I don't know what I'm missing, but I just want to make a simple sequential polyline that runs through the order of points and generates a smooth trail with slope visuals.
Can someone please tell me what I'm missing?
DanPatterson_Retired
Were the points in the actual order or did you sort them? sorting doesn't work BTW, they have to be sequential.
Maybe a short sequence of points to make sure that X and Y haven't been switched or Z isn't being plotted against X or Y.
MATTHEWTOMITZ
The points have no ordering themselves, they were generated by Raster to Point.  They are positioned in such a way that they follow the trail.  Is there some way I can add a sequence of numbers?  I will have a couple thousand points, so manual would take a long, long time.
could you not use http://pro.arcgis.com/en/pro-app/tool-reference/spatial-analyst/extract-by-points.htm
assuming your points were in sequential order.
There is no way to order points in some sort of order unless you can provide the rule for the sort... then anything is possible.
MATTHEWTOMITZ
The points are in a line, so a sequence can be inferred.  They don't have a field that gives a good sequencing.  They have ObjectID codes, but the numbers jump around through the several thousand points, so point 1 could be next to point 3759.  The Extract by Points tool asks for XY coordinates for every point, and doesn't seem very tenable to my limited experience.
I have had success reordering points using a lexicographic or radial sort... the ability to do so easily depends on how snakey the line is.  If the line folds back on itself then sorting isn't going to work.  Maybe construct a line manually, densify it, segment it and see if you can get the points to snap to it using a spatial join.  It sounds worse that it really is
MATTHEWTOMITZ
I do have some trails that don't make an easy line, they do curve on themselves or have splits.  And yeah, that does sound a bit confusing.  To be clear, I should:
Make a line shapefile, use Editor to draw lines of the trails.
Use a Density (?) tool
Segment the line, I guess into polylines
Spatially join the points to the line
I think that's not so bad, I'll try it.
Densify... not Density.
Yes, draw the polyline as best you can... Densify the line,  And I am hoping you have an Advanced license
because you have to split the lines at the vertices http://desktop.arcgis.com/en/arcmap/latest/tools/data-management-toolbox/split-line-at-vertices.htm
or at least a standard license so you can snap your points to the line http://desktop.arcgis.com/en/arcmap/latest/tools/editing-toolbox/snap.htm
otherwise it will be some searchcursor thing
