TIN to Raster tool crash in ArcMap
2983
12
04-14-2018 02:54 AM
CrystalBrochard
I have some trouble with the TIN to Raster tool.
Each time I try to create a raster from a TIN file, ArcMap crashes and has to close.
I'm doing a formation on ArcGIS 10 and I cheked the input file with the people of the formation, it is fine.
Maybe too heavy (50,8Mo in total) ?
I set the environment, I try to convert the file with no other layers in the data frame,...evering I'm doing doesn't change a thing.
The parametors I'm trying to use are:
- input TIN checked
-Output raster in a geodatabase
- INTEGER
- natural neighbors and linear (I have to create two rasters, each of them with a different method)
- cellsize 25
- z factor 1 (default)
It's the only tool I can't use, I don't understand what's wrong with it. As far as I can see on the forum, nobody seems to have trouble executing the tool with ArcMap.
A little bit of help would really be appreciated,
XanderBakker
Esri Esteemed Contributor
What version of ArcMap are you using? A TIN of approximately 50MB isn't very big and shouldn't generate ArcMap to crash. Try the following:
Resetting your ArcGIS application profile
and switch off Background Geoprocessing (64-bit)—Help | ArcGIS Desktop
CrystalBrochard
I tried to reset the application profile with the steps detailed, and the background geoprocessing was already switch off ; but ArcMap still crashed.
Maybe I didn't activate something ?
XanderBakker
Maybe in this case it is best to contact Esri Support and work through the problem and see what is happening on your computer. As I said before, ArcMap should not crash, especially not when the data is relatively small.
CrystalBrochard
Ok thanks, I really think that there is a problem my my ArcMap, now another tool is not working.
Thanks for your help !
XanderBakker
In that case contacting Esri Support would probably best or do a re-install if resetting the mxt does not work.
JayantaPoddar
MVP Esteemed Contributor
Also check the spatial reference of the dataset. For a cellsize of 25 m, the dataset should have a Projected Coordinate System (Unit=Meters).
Think Location
CrystalBrochard
I was already using projected coordinates, but I will take note of this for the future.
DanPatterson_Retired
Perhaps an image of what you are using.
Have you tried it with a different file?
Have you tried creating a small simple tin and convert it?
Can you show the inputs to the tool dialog?
CrystalBrochard
I tried with a different file, lighter than the previous one, and the tool still make ArcMap crashed.
