AnsweredAssumed Answered
can I change symbology based on multiple fields in AGOL?
Question asked by LBerni@slco.org_slco on Apr 13, 2018
Latest reply on Oct 1, 2018 by jroland@swbno.org_swbno
Is it possible to customize the symbology in AGOL based on multiple fields, like I would in ArcMap (or Pro) using the "unique values, many fields" option?
In AGOL, I can select a specific field (attribute), which is great. But then when I go to add a second attribute, only those fields with numeric data are available in the dropdown and this second attribute is used to rank or numerically represent the data in field 1. Erg!
My work-around was to add my Waterways data to the map twice (since I need two fields to get the symbology the way I want), and adjust the symbology for each field respectively. Not ideal of course, but It worked well enough for this particular situation,
Any suggestions would be most appreciated.
Thanks!
Lynn
Outcomes
