Export Web Map - print labels
844
04-13-2018 07:31 AM
MassimilianoSantini
Hi all,
I have built two FeatureLayer (3.14) in client-side from JSON objects .
They contains both simple points, one with some yellow circle and one with a star.
I have set labelingInfo for one as show in the image above. It works fine.
Now, I have tryed to print the map using the ESRI Export Web Map Service
and the image obtained doesn't have labels.
I call the service with this request, any suggest????
f=json&Format=PNG32&Layout_Template=MAP_ONLY&Web_Map_as_JSON=
    "mapOptions": {
        "showAttribution": false,
        "extent": {
            "xmin": 1378137.0264387086,
            "ymin": 5475499.428862644,
            "xmax": 1385780.729267216,
            "ymax": 5483143.131691152,
            "spatialReference": {"wkid": 102100}
    "operationalLayers": [
            "url": "https://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"
            "featureCollection": {
                "layers": [
                        "layerDefinition": {
                            "typeIdField": "",
                            "objectIdField": "id",
                            "name": "Concorrenza",
                            "drawingInfo": {
                                "renderer": {
                                    "type": "simple",
                                    "symbol": {
                                        "color": [247,168,0,255],
                                        "size": 13,
                                        "angle": 0,
                                        "xoffset": 0,
                                        "yoffset": 0,
                                        "type": "esriSMS",
                                        "style": "esriSMSCircle"
                                "labelingInfo": [
                                        "labelExpression": null,
                                        "labelExpressionInfo": {
                                            "value": "{id}"
                                        "format": null,
                                        "fieldInfos": null,
                                        "useCodedValues": false,
                                        "maxScale": 0,
                                        "minScale": 0,
                                        "where": null,
                                        "sizeInfo": null,
                                        "labelPlacement": "esriServerPointLabelPlacementCenterCenter",
                                        "symbol": {
                                            "color": [0,0,0,255],
                                            "type": "esriTS",
                                            "horizontalAlignment": "center",
                                            "angle": 0,
                                            "xoffset": 0,
                                            "yoffset": 0,
                                            "text": "",
                                            "rotated": false,
                                            "kerning": true,
                                            "font": {
                                                "size": 9,
                                                "family": "Arial"
                            "type": "Feature Layer",
                            "fields": [
                                    "name": "id",
                                    "alias": "ID",
                                    "type": "esriFieldTypeOID"
                                    "name": "nome",
                                    "alias": "NOME",
                                    "type": "esriFieldTypeString"
                                    "name": "via",
                                    "alias": "VIA",
                                    "name": "cap",
                                    "alias": "CAP",
                                    "name": "citta'",
                                    "alias": "Citta'",
                                    "name": "prov",
                                    "alias": "PROV",
                            "geometryType": "esriGeometryPoint",
                            "types": [],
                            "capabilities": ""
                        "featureSet": {
                            "features": [
                                    "geometry": {
                                        "x": 12.4024018102496,
                                        "y": 44.0992129263624,
                                            "wkid": 4326
                                    "attributes": {
                                        "id": 1
                                    "geometry": {
                                        "x": 12.395513230862,
                                        "y": 44.0937650870184,
                                        "spatialReference": {"wkid": 4326}
                                    "attributes": {
                                        "id": 2
                        "nextObjectId": 6
                "layers": [
                            "name": "PSP",
                            "drawingInfo": {
                                "renderer": {
                                    "symbol": {
                                        "size": 16,
                                        "imageData": "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",
                                        "width": 16,
                                        "type": "esriPMS",
                                        "contentType": "image/png",
                                        "url": "cee6af51be187ef858113fdceb992826",
                                        "height": 15
                                    "type": "simple"
                            "fields": [
                                    "name": "id",
                                    "alias": "id",
                            "capabilities": ""
                        "featureSet": {
                            "features": [
                                    "geometry": {
                                        "x": 12.40899,
                                        "y": 44.092698,
                                    "attributes": {
                                        "id": 100
                        "nextObjectId": 101
    "baseMap": [],
    "exportOptions": {
        "outputSize": [2060,1400],
        "dpi": 300
    "layoutOptions": {}
Massimiliano
FMISSinarmas_Forestry
Hi Massimiliano Santini
Have you solved this issue? I have the same problem the label of featureCollection does not display in the print result.
MassimilianoSantini
no I haven't, the project ended shortly after and I never investigated again.
I'm sorry
Bye
Massimiliano
Noah-Sager
Could you share a codepen or simple repro case? What is the version of the Print Service you are using?
