Copying a Point Shape@ from a SearchCursor to a InsertCursor
2573
7
04-11-2018 01:31 PM
DougBrowning
MVP Esteemed Contributor
I am trying to copy a Point from a SearchCursor to a InsertCursor but I can never get the geometry to work.  In past projects I ended up giving up on it and just did a Append then insert to get around it but I want to figure it out (unless this is a good way?).
First note that the Search FC and the Insert FC are different projections.  It may be that arc will not handle this for me.
This is like what I am trying (mini version) but it gives a AttributeError: __exit__
FROM
    fields = [ 'SHAPE@']
    with arcpy.da.SearchCursor(plotLayer, fields) as cursor:
        for row in cursor:
            saveShape = row[0]
TO
   insertFields = [ 'SHAPE@']
    with arcpy.InsertCursor(terraFC, insertFields) as inCursor:
        inCursor.insertRow(saveShape)
I have also tried SHAPE@XY and still no.  It seems like I have found code like this that works for Polygons but not points. Almost all examples of Point always use a x,y.
Thanks a lot for any help
Tags (1)
JoshuaBixby
Fortunately, ArcPy Data Access search cursors do projection on the fly, which saves you from having to explicitly project the data after retrieving it.  Also, since you are working with points, ArcPy Data Access insert cursors will automatically create the PointGeometry objects for you from a tuple representing an X,Y coordinate.
fields = ["SHAPE@XY", "field1", "field2"]
wkid = # WKID of destination FC
SR = arcpy.SpatialReference(wkid)
with arcpy.da.SearchCursor(plotLayer, fields, spatial_reference=SR) as cur:
    with arcpy.da.InsertCursor(terraFC, fields) as icur:
        for row in cur:
            icur.insertRow(row)
RandyBurton
I've used something like the following:
import arcpy
srcFeature = r'C:\Path\To\geodatabase.gdb\test1'
srcFields = ['SHAPE@X', 'SHAPE@Y', 'MyField'] # x & y plus additional fields as needed
srcSR = 3857 # Web Mercator - change as needed
destFeature = r'C:\Path\To\geodatabase.gdb\test2'
destFields = ['SHAPE@X', 'SHAPE@Y', 'MyField'] # x & y plus additional fields as needed
destSR = 4326 # WGS 1984 (Lat/Lon) - change as needed
whereClause = '1=1' # edit as needed
with arcpy.da.InsertCursor(destFeature, destFields) as destCursor: # destination - insert cursor
    with arcpy.da.SearchCursor(srcFeature, srcFields, where_clause=whereClause) as srcCursor: # source - search cursor
        for srcRow in srcCursor:
            destRow = [None]* len(destFields) # initialize destRow for number of fields to be inserted
            ptGeometry = arcpy.PointGeometry(arcpy.Point(srcRow[0], srcRow[1]), arcpy.SpatialReference(srcSR)).projectAs(arcpy.SpatialReference(destSR))
            destRow[0] = ptGeometry.firstPoint.# x coord
            destRow[1] = ptGeometry.firstPoint.# y coord
            destRow[2] = srcRow[2] # additional field(s)
            destCursor.insertRow(destRow)
del destCursor, srcCursor
For spatial reference, use WKID number.  You can add additional fields, if you want them transferred.  I've added a generic where clause which can be modified if you only have a specific group of points to transfer.  Hope this helps.
DarrenWiens2
MVP Honored Contributor
I'll just draw attention to the fact that in the (correct) example above PointGeometry and Point are two completely different objects, and they must be handled with care.
JoshuaBixby
        for row in cur:
            icur.insertRow(row)
DougBrowning
Thanks a lot Joshua - great code.  It took a minute because of a different issue.  If you look close at my post I had the old Insert and missed the new .da part!  Duh.  That fixed a lot.
I did change your code slightly to ask the outgoing FC its projection and then use that.  This way it will work even if the SR is different that the hardcoded wkid.  Works but if this is an issue let me know.
    sr = arcpy.Describe(terraFC).spatialReference
    fields = ["SHAPE@XY"]
    whereClause = "PlotKey = '" + plot + "'"   # only want completed plots from above
    with arcpy.da.SearchCursor(plotLayer, fields, whereClause, spatial_reference=sr) as cursor:
        for row in cursor:
            dataValues.append(row[0])
for eachData in allDataValues:
    with arcpy.da.InsertCursor(terraFC, insertFields) as inCursor:
            inCursor.insertRow(eachData)
I also wonder if you did  fields = ["SHAPE@"] if it would work for any geometry type?
It all works!  Thanks again to everyone.
DanPatterson_Retired
The difference is SHAPE@ returns a geometry object, SHAPE@XY goes an extra step and returns the coordinates.  It depends whether you need to do something with the geometry or the coordinates, a subtle but important distinction
for row in arcpy.da.SearchCursor(in_fc, ["SHAPE@"]):
    # Print x,y coordinates of each point feature
    print(row[0])
<geoprocessing describe geometry object object at 0x000002898716CDA0>
<geoprocessing describe geometry object object at 0x000002898716C6C0>
... snip
for row in arcpy.da.SearchCursor(in_fc, ["SHAPE@XY"]):
    print(row[0])
(340500.00000000047, 5020500.000000002)
(341500.0000000014, 5020500.000000002)
(342500.00000000093, 5020500.000000002)
(343500.00000000047, 5020500.000000002)
(344500.0, 5020500.000000002)
(340500.00000000047, 5021500.0)
(341500.0000000014, 5021500.0)
(342500.00000000093, 5021500.0)
(343500.00000000047, 5021500.0)
(344500.0, 5021500.0)
(340500.0000000004, 5022500.000000001)
(341500.00000000146, 5022500.000000001)
(342166.66666666855, 5022500.000000001)
(343500.00000000047, 5022500.000000001)
(344500.0, 5022500.000000001)
...snip
DougBrowning
I just want to copy the geometry from A to B.  Not change it in any way.
thanks
DougBrowning
I tested and using just SHAPE@ works just fine.  That means this code should work for any type of FC.
