How to extract census block groups that touches a buffer
1471
04-10-2018 12:02 PM
VirginiaSapkota
Good Afternoon,
I would like to request assistance. I want to extract census block groups (yellow polygons) that touches the 1/2 mile buffer (purple polygon). What is the tool I can use?
Thank you,
Virginia Sapkota
ChrisDonohue__GISP
There are several ways to do this.  Here's probably the easiest workflow:
  1. With both layers loaded into ArcGIS, use Select By Location  Using Select By Location—Help | ArcGIS for Desktop
  2. Export the resulting selected information from the Census Block groups to a new feature class.
Chris Donohue, GISP
VirginiaSapkota
Thank you very much Chris, it works! I now have selected the block groups.
I have another question. If suppose I want to select counties based on their FIPS, e.g., Dallas County has FIPS 48113. How can I select using select by attributes query?
Thanks again,Virginia
ChrisDonohue__GISP
Here's the process instructions:
Using Select By Attributes—Help | ArcGIS for Desktop
Chris Donohue, GISP
