Microsoft Edge doesn't load data when using Javascript API
3760
04-10-2018 07:27 AM
MKF62
The Javascript API 3.23 site says that it supports Microsoft Edge, but I cannot get any of my data to load in an edge browser. It only loads the basemap. In Chrome, my feature layers show up, in Edge, they do not. Anybody else encounter this problem? I get a couple error messages:
SCRIPT5: Access denied.
SEC7117: Network request to https://xxx/rest/services/HbMonitoringTest/HabitatData/MapServer/2?f=json&callback=dojo_request_scri... did not succeed. This Internet Explorer instance does not have the following capabilities: privateNetworkClientServer
I'm not using any proxies or doing anything weird, it's a pretty simple set up:
var cipCentroidsFL = new FeatureLayer("https://xxx/rest/services/HbMonitoringTest/HabitatData/MapServer/0", {
      refreshInterval: 1440,
    cipCentroidsFL.setMaxScale(1000000);
    cipCentroidsFL.setMinScale(20000000);
    var cipAreasFL = new FeatureLayer("https://xxx/rest/services/HbMonitoringTest/HabitatData/MapServer/3", {
      infoTemplate: cipPopupBox,
      outFields: ["*"]
    cipAreasFL.setMinScale(999999);
    var patchesFL = new FeatureLayer("https://xxx/rest/services/HbMonitoringTest/HabitatData/MapServer/1", {
      refreshInterval: 10,
      definitionExpression: 'EXTRACT(YEAR FROM "ObsvDate") = '+ currentYear,
      infoTemplate: patchesPopupBox,
      outFields: ["*"]
    patchesFL.setMinScale(500000);
    var protectCoverFL = new FeatureLayer("https://xxx/rest/services/HbMonitoringTest/HabitatData/MapServer/2", {
      definitionExpression: 'EXTRACT(YEAR FROM "ObsvDate") = ' + currentYear,
      visible: false,
      infoTemplate: pcPopupBox,
      outFields: ["*"]
    protectCoverFL.setMinScale(500000);
    patchesFL.setRenderer(qhRenderer);
    protectCoverFL.setRenderer(pcRenderer);
    cipAreasFL.setRenderer(cipRenderer);
    map.addLayers([cipAreasFL, cipCentroidsFL, patchesFL, protectCoverFL]);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Tags (1)
DanPatterson_Retired
is it enabled?  from windows help
For Microsoft Edge, you can disable/enable Javascript from Windows Group Policy editor. Kindly follow the steps below:
1. Click on Start, type Edit group policy and select it.
2. Expand the User Configuration -> Administrative Templates -> Windows Components folder.
3. Expand the Microsoft Edge folder
4. Double-click allows you to run scripts, like Javascript.
5. Choose Disable and click OK to confirm.
MKF62
Unfortunately I do not have that setting.
I'm not clear why I would want to disable Javascript anyway? I think you meant "enable" in your last direction.
