Portal asking for server credentials when I opening an unsecure service in a WebMap
762
04-11-2018 03:14 AM
EmilienMeffe
Hello everyone,
I try to include a feature layer and a MapLayer in a web map in the Portal, It works but when I try to open the web map the Portal asks for my server credentials.
The service is not secure and should not ask me credentials. I tried to following esri configurations advice :
-   added my arcgis server in "trusted server" setting,
-   modification of the "Webcontext" setting in the portal
but i still have the same problem.
We are working with versions 10.4 of the Portal and 10.3.1 of the Arcgis Server (They are not federated).
Maybe there is a configure error somewhere?  Any help is appreciated
MohyudinAhmad
Salut Emilien,
I believe that you may be running into a known bug which was addressed at 10.4. Are your Portal and ArcGIS Server on the same machine? If so, the following may be the problem...
BUG-000086352
'The map viewer prompts for credentials when adding an unsecured map service layer from an unfederated ArcGIS Server running on the same machine.'
http://downloads.esri.com/support/downloads/other_/104-IssuesAddressedList.pdf
J'espère que ça t'aidera un peu!
