Can the Attribute Assistant's DynamicValue table be versioned? I've seen multiple places that the GenerateID table cannot be, but nothing specific to the DynamicValue one.
Solved! Go to Solution.
Short answer is yes: any table can be versioned, but if you version the Dynamic Values table there is a good cchance it'll goof on you. I don't version the Dynamic Values table, and use it as such in an enterprise GDB which contains versioned feature classes and it's those feature classes that AA is assigned to.
I am also interested in knowing if this is possible as I can see it causing problems trying to use the Attribute Assistant with versioned SDE data?
