Survey 123 Error
1231
04-06-2018 01:26 PM
JohanHendrickson
Survey 123 users are receiving the following error when attempting to submit on an existing survey:
"Failed to submit. Unable to add the features. This operation is not supported."
I have contacted ESRI Customer support and opened a case.  Just wondering if anyone else has had this problem.
JohnathanHasthorpe
Hi Johan
Can you confirm that this affects a specific survey or multiple surveys?
It looks like the permissions on the feature service may have been changed to not allow new features to be added. Can you go to the feature service item in ArcGIS Online and check the service permissions?
John
JohanHendrickson
John,
The error only affects this survey. Feature layer is shared with everyone.
Sincerely,
Johan
Johan Hendrickson
GIS Analyst
City of Largo / IT Business Services
727-587-6740 Ext. 6824
jhendric@largo.com
JohnathanHasthorpe
Hi Johan
Can you also check the service permissions to make sure that you can add new features:
If the service permissions are OK, can you share the survey .xls and I will see if I can replicate.
John
