MapInfo files to be opened in ArcGIS
28650
9
04-05-2018 05:37 AM
francescarusso
New Contributor III
I have received a:
.DAT
.ID
.MAP
.TAB
files which as far as I understand are MapInfo files.
I need to open them in my ArcGIS 10.2.2. Any suggestion on how to convert them?
many thanks ,
f
RobertBorchert
Frequent Contributor III
Best thing would be to use MapInfo to convert them to shapefiles.
Otherwise use the Quick Import Tool
francescarusso
New Contributor III
dear Robert,
thank you for your reply. I think I do not have access to this tool as when I click on it I got a red cross. Please see screenshot.
I do not have either MapInfo to convert it.
any other sugg estion?
thanks
ThorbjørnSøndergaard
You need the Data Interoperability Extension for ArcGIS to use the Quick Import tool.
AbdullahAnter
Occasional Contributor III
Do you have MapInfo software?
francescarusso
New Contributor III
NO, I  am afraid I od not have
XanderBakker
Esri Esteemed Contributor
From the command line using GDAL: GDAL - Geospatial Data Abstraction Library  you can use GDAL: ogr2ogr to convert to a shapefile.
RobertBorchert
Must be an extension issue. If you can find somebody who has an Advanced license who is willing to convert it that could be an option.
Check out Xander Bakker suggestion.
MarkFawkes
This might also help? I have never had to do a conversion from MapInfo.
https://esriaustraliatechblog.wordpress.com/2016/02/16/a-hidden-gem-how-to-convert-mapinfo-files-mif...
Su-AnnKoh
Using QGIS is the easiest solution I'm afraid - shapefile - Converting MapInfo TAB and/or MIF to SHP using free tools or ArcGIS for Desktop core pro...
Regards,
   Leandra Gordon (on Su-Ann Koh's account)
