Symbology
614
04-05-2018 09:36 AM
PrestonStafford2
Hello I'm seeking some help in figuring out what is wrong with my symbology within my feature classes. My feature classes are stored  within a SDE database. When I try to go and click on a feature in my Create Feature window, there is no symbology for the feature,(See Attachement). There fore the features symbology doesn't show up on the map either. I'm currently using 10.4 Arcmap.
Tags (1)
ChrisDonohue__GISP
Some possibilities:
  • Is there currently a symbology layer stored in SDE for the feature classes?  For example, is there a .lyr file for the feature class?  If not, you may need to create .lyr files from the existing symbolized feature classes.
Layer Files
  • Or is the issue more specifically that the feature class is correctly symbolized in the Table of Contents in ArcMap (with either the use of a lyr file or symbology created manually), but the in the Create Features window the Template does not show the symbology?  If that is the case, you may need to work on the FeatureTemplates.
About feature templates—Help | ArcGIS for Desktop
Chris Donohue, GISP
PrestonStafford2
Yes, I have them in lyr.for the symbology.
Thank you
Preston Stafford
Bonneville County Public Works
1-208-529-1290 ext. 3504
