Geoprocessing services and system load
626
5
04-04-2018 10:33 AM
BobBistrais
New Contributor III
We are considering adding geoprocessing services on our ArcGIS Server infrastructure, and wondering what others' experiences were.  Effect on performance is the biggest concern.  I realize there are lots of variables there, but a specific use case would be a service which buffers point data.  We currently have a single server site but expecting to bring a second server online soon.  Alternatively considering using ArcGIS Online geoprocessing services, although that consumes credits.  Wondering what others have done.  Is there a reliable way to estimate performance impact, given an anticipated use case?
ChadKopplin
Occasional Contributor III
We are currently using this in a number of our web app's, for what you are doing this may not be a major work load, and with adding another server to load balance the system this should help as well, because if one is being used for processing it will flip the load to the other server.  Do you have an ArcGIS server license?  If so you can create a map service of your geoprocessing service and serve it from your server, this will not consume any credits.
BobBistrais
New Contributor III
Hi Chad,
Yes we do have an ArcGIS Server license.  You mentioned that you are doing this- can you expand on how you're using it and share experience, problems, or advice?
JonathanQuinn
Esri Notable Contributor
It's difficult to provide expected results of any type of load test, as there are a number of variables to consider:
1) Resources on the machine
2) Other processes/software running on the machine
3) Where the data is located
4) Parameters specific to the tool, (dissolve edges, etc)
5) Number of users accessing the service
6) Location of the directories, (UNC or non-local paths will take a performance hit)
The best way to determine performance impact is to run a performance load test using something like JMeter or even something simple like Python. You can write a simple script that uses the threading module to simulate x number of users hitting the service at a given time. A proper load test application like JMeter or Road Runner will give you the best results, and JMeter is also free, which is a plus.
RandallWilliams
Are you literally just buffering points? ArcGIS Server's default geometry service will do that and more.
What is the geometry service?—Documentation | ArcGIS Enterprise
GeometryService | API Reference | ArcGIS API for JavaScript 4.6
BobBistrais
New Contributor III
Still trying to determine exactly what the client wants, but it's likely that the Geometry Service with buffer task would work.
