AnsweredAssumed Answered
Code 0 on Survey123
Question asked by deleted-user-jxpbpbjlZInj on Apr 3, 2018
Latest reply on Apr 3, 2018 by JTedrick-esristaff
I have a crew that's working in the field, often offline, to collect data with Survey123. Occasionally, they are running into an issue where, when they try and send from their outbox, they get a "Code 0" and the survey will not send. I found this in an ESRI Blog:
"BUG-000108893: Using Survey123 for ArcGIS field app, if a survey is taken while Offline, then the device is switched to Online, pending surveys in the Outbox will fail to send with Code 0."
So... has this been fixed? That seems to defeat the purpose of using Survey123 in the first place and it didn't seem to happen in older versions!
Any help would be appreciated. This is a HUGE problem for us right now!
Outcomes
