AnsweredAssumed Answered
How do you determine which map frame is active in a layout?
Question asked by TomFlahive on Mar 30, 2018
Latest reply on May 16, 2018 by jbarrette-esristaff
I would like to resize a map frame in a layout.  If the layout has more than one map frame, as in the screenshot below, how can I determine which map frame is currently the active map frame (which shows as bolded in the Contents pane)?
Select map frame in a layout with multiple map frames.
I checked the MapFrame object and the Layout object, but did not see any properties that would tell me which map frame is active.
Outcomes
