AnsweredAssumed Answered
Sum rasters failing with "Unexpected error"
Question asked by cpyywhite on Mar 27, 2018
Latest reply on Mar 27, 2018 by xander_bakker
Hi, I am very new to python and am coming across an issue that I haven't been able to work out on my own.
I have 9 rasters that I need to sum. Nothing fancy, just a simple sum. I have this code that I used in another script (found on some blog somewhere) and it worked without any issue whatsoever:
    rasters = arcpy.ListRasters('cf_*')
    i = 0
    for ras in rasters:
        if i == 0:
            sumras = arcpy.Raster(ras)
            i += 1
        else:
            sumras = sumras + ras
            i += 1
    sumras.save(outRasterCFS)
However, in my current script it fails with:
  File "<module1>", line 32, in <module>
  File "<module1>", line 25, in Cut
  File "C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\sa\Functions.py", line 4329, in Plus
    in_raster_or_constant2)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\sa\Utils.py", line 53, in swapper
    result = wrapper(*args, **kwargs)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\sa\Functions.py", line 4326, in Wrapper
    ["Plus", in_raster_or_constant1, in_raster_or_constant2])
RuntimeError: ERROR 999998: Unexpected Error.
When researching how to resolve this, I found another post somewhere that suggested cellstatistics might be better, so:
sumras = CellStatistics(rasters,"SUM","DATA")
But it fails with:
  File "<module1>", line 16, in Cut
  File "C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\sa\Functions.py", line 3149, in CellStatistics
    ignore_nodata)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\sa\Functions.py", line 3145, in Wrapper
    [function] + Utils.flattenLists(in_rasters_or_constants))
Usually, when I run into problems that aren't very clear, I run it manually from ArcMap and can usually figure out what is going wrong in my python, but when I run CellStatistics from ArcMap, it fails as well:
ERROR 010092: Invalid output extent.
I really have no idea where to go from here. I can't find anything online that points me in a helpful direction...
Any thoughts or suggestions? I would greatly appreciate it!
Here is the entire script:
#Set environment
import arcpy
from arcpy import env
from arcpy.sa import *
wrkpath = r'E:\GIS_Data\GEO5419\MyWork'
arcpy.env.workspace = wrkpath
def Cut():
    topRaster = 'Site_DEM'
    outRasterCFS = wrkpath+'\CFSum'
##    i = 0
##    for ras in rasters:
##        if i == 0:
##            sumras = arcpy.Raster(ras)
##            i += 1
##        else:
##            sumras = sumras + ras
##            i += 1
##    sumras.save(outRasterCFS)
    arcpy.CheckInExtension("Spatial")
if __name__ == '__main__':
    Cut()
Outcomes
