Directions widget, multiple preset stops?
1107
03-26-2018 01:10 PM
RobertLackage
New Contributor III
Is it possible to add more preset stops then just the start and end points in the directions widget? I'd like to have preset directions for multiple points.
RobertScheitlin__GISP
Robert,
  In the Widget.js file make this change to the _onDirectionsActivate function:
      _onDirectionsActivate: function () {
        if (this.config.defaultLocations &&
          this.config.defaultLocations.length && this.config.defaultLocations.length > 0 &&
          false === this._isInitPresetStopsFlag) {
          this._isInitPresetStopsFlag = true;
          this._dijitDirections.addStops(this.config.defaultLocations);
          this._dijitDirections.addStop();
Robert,
   are you asking for the directions widget to open with more then the 2 default stops? If so how many?
RobertLackage
New Contributor III
Yes, I'd like 6 default stops to be preset.
Robert,
RobertLackage
New Contributor III
Thanks Robert! Your eSearch is the best btw.
