Privileges, Register as Version commands are greyed out when right-clicking a feature class in an ArcSDE geodatabase
6403
5
03-23-2018 01:42 PM
AhmadSALEH1
When right-clicking a feature class in an ArcSDE geodatabase from ArcGIS Desktop, the 'Privileges', ‘Register As Version’ commands are grayed out even though the user is connected as the data owner, and (Advanced) ArcGIS Desktop license is being used.
In my case the data owner is the ‘SDE’ user, I restored this database from the backup to a new SQL server instance on a test machine, The SDE user is able to connect to the database and view the feature classes, now I am trying to assign privileges to users and register the feature classes as versioned and I found out that the Privileges, Register as Version commands are grayed out!
I made sure that I am using the SDE user who owns the data and an Advanced license of ArcMAP 10.5.0 https://support.esri.com/en/technical-article/000009946
I tried to use change privileges (data management) tool but I got this error!
ERROR 999999: Error executing function.
DBMS table not found [42000:[Microsoft][ODBC Driver 13 for SQL Server][SQL Server]Cannot find the object 'CanLocations_evw', because it does not exist or you do not have permission.]
Failed to execute (ChangePrivileges).
I checked the view in the database in its there!
What might be the issue here!
Thanks in advance
Ahmad
Asrujit_SenGupta
You might have granted the SYSADMIN server role to the SDE login, which will make it a DBO schema user and thus those options will be grayed out.
Just as a quick test, you can try creating a simple table or a feature class, connected as the SDE login and check the Data Owner schema.
Did you resync the SDE login after restore of the database?
How To: Re-synch SQL Server logins or users after restoring a database from backup
Asrujit_SenGupta
AhmadSALEH1
Asrujit, You Are A Hero!
I have granted the SYSADMIN server role to the SDE login, I thought this would be better, more permissions means more power to the user ! which is not.
After removing the sysadmin role everything back to normal.
Thanks a lot
yockee
Why does being granted SYSADMIN limit the capability to Register as Version ? Isnt it better to have more role ?
Need your enlightment.
thank you
VinceAngelo
Esri Esteemed Contributor
Cross-posted to GIS StackExchange
AhmadSALEH1
Thanks V for the helpful notes.
