How do I modify the callout pointers what I want ?
443
03-23-2018 08:48 AM
PROBERT68
I am trying to get my pointer to modify from the box that says You are Here. What I wanted to move the call out on the top of the box and point to the start
It looks like this
If I move the box to a bit to the left because it is in the way for words "Rainbow Fails" . I need to show that words . If I move it a bit to the left the pointer will change to like this
I do not want the pointers on the right side of the box.. I want it to keep at the top ?  How do I make it this work ?
The reason I want to make it to the top to stay out of the words tand the roads that need to be shown...
I am using 10.3.1 in Citrix at that moment .
PROBERT68
BINGO !!!!!!!!!!!!!!!!!!!
Earlier I post what I was trying to ask about an issue I came across so....
This is NOT what I wanted :
I finally figure it.
So this is WHAT I want this way :
Here is how to do this....
Open it up the properties and set the Angle to very very low like 0.1 .
So it doesn't look like it is rotate a lot ...  just my one cent simple.
P.S. I revised a bit here.....
If you have a way around similiar what I was doing please share with me
Thanks !
