4.x hitTest issue
999
03-22-2018 05:53 PM
JeremyLuymes
New Contributor III
Getting a weird error every once in a while for a hitTest function (still using 4.4 to avoid another bug but it happens in 4.6 as well).
EDIT: confirmed in Esri samples this a bug with the hitTest function. This seems to be fixed if i test in 4.7.
    view.then(() => {
      view.whenLayerView(nbhdLyr).then(function(lview2){
        watchUtils.whenFalse(lview2,"updating",function(){
          view.on("pointer-move",eventHandler2);
          function eventHandler2(event) {
            view.hitTest(event).then(getGraphics2);
It then passes to a function that sends attributes to a popup
    function getGraphics2(response2) {
      if (response2.results.length) {
        var graphic = response2.results.filter(function(result2) {
          return result2.graphic.layer === nbhdLyr;
        })[0].graphic;
        var attributes = graphic.attributes;
        var nbdattr = attributes.NEIGHBOURHOOD;
        var poattr = attributes.PREORDERS;
        var cusattr = attributes.CUSTOMERS;
        var intattr = attributes.INTERESTLEVEL;
        var mrkattr = attributes.MARKETPEN;
        var addrattr = attributes.PROPERTIES;
        var pconvattr = attributes.POCONV;
        document.getElementById("info").style.visibility = "visible";
        document.getElementById("nbhd").innerHTML = nbdattr;
        document.getElementById("preorders").innerHTML = " <b>" + poattr + "</b> preorders";
        document.getElementById("customers").innerHTML = " <b>" + cusattr + "</b> customers";
        document.getElementById("interest").innerHTML = " <b>" + intattr + "%</b> total interest";
        document.getElementById("marketpen").innerHTML = " <b>" + mrkattr + "%</b> market penetration";
        document.getElementById("address").innerHTML = " <b>" + addrattr + "</b> addresses";
        document.getElementById("poconv").innerHTML = " <b>" + pconvattr + "%</b> preorders converted";
This will sometimes give an error on the hitTest function, saying:
Uncaught TypeError: Failed to execute 'elementFromPoint' on 'Document': The provided double value is non-finite.
Image is also attached. I'm not sure what's causing this or how to get around it, anyone see this issue or have any thoughts?
JeremyLuymes
New Contributor III
I was able to replicate this error in an Esri sample: ArcGIS API for JavaScript Sandbox
So i guess it must be a bug with the hitTest function.
JeremyLuymes
New Contributor III
To add more context to this, it seems it's only happening when i'm near the left border of my map. Very strange.
JeremyLuymes
New Contributor III
