AnsweredAssumed Answered
Triggering symbology to change 14 days after a domain gets change in feature service
Question asked by Sophie_Humphry on Mar 22, 2018
Latest reply on Mar 29, 2018 by xander_bakker
We are using the collector app for our grass cutting programme where crews are required to cut the grass every 14 days. We are using a feature service with a related table to retain the cutting history and we want to be able to set the symbology to change 14 days after the status in the related table is changed from 'Not Cut' to 'Cut'. After searching the forums I haven't seen a solution that triggers a change in symbology based on the lasted entry in a related table connected to that particular polygon.
A work around is we are getting crews to add a 'new inspection' in the related table and then go back into the feature service and edit the status from 'Not Cut' to 'Cut'. Is there a way using Arcade Expressions to trigger the symbology to change 14 days after the 'cut' status has been selected to 'due cut'?
Thanks...Sophie
Outcomes
