AnsweredAssumed Answered
laharz
Question asked by cmoserinburke on Mar 21, 2018
Latest reply on Mar 22, 2018 by Dan_Patterson
Wondering if somebody can help me with some errors generated by the LaHarz model.  I am trying to run the Laharz Distal Zones standalone python tool.  It was created by a USGS developer and it is supposed to work with ArcGIS 10.X.  There are four required inputs: 1) filled DEM, 2) text file of volumes (integers), separated by commas 3) a text file of XY coordinates and 4) a string denoting a prefix for output grids.  Below is the message in Geoprocessing Results.  The full python script will be attached.
Executing: laharzdistalzones.py C:\Users\cmoser\Downloads\laharz_py_example\mtrain_example fill mtrwest_ C:\Users\cmoser\Downloads\laharz_py_example\mtrain_example\laharz_textfiles\volumesrockfall.txt C:\Users\cmoser\Downloads\laharz_py_example\mtrain_example\point_textfiles_for_ArcMap\points.txt Rock_Avalanche
Start Time: Wed Mar 21 17:19:08 2018
Running script laharzdistalzones.py...
Parsing user inputs:
Running Laharz_py
_________ Input Values _________
Input Surface Raster Is:fill
Volume textfile :C:\Users\cmoser\Downloads\laharz_py_example\mtrain_example\laharz_textfiles\volumesrockfall.txt
Starting coordinates file :C:\Users\cmoser\Downloads\laharz_py_example\mtrain_example\point_textfiles_for_ArcMap\points.txt
Drainage identifier :mtrwest_
Rock Avalanche Selected
_________ Paths on Disk _________
full path fill :C:\Users\cmoser\Downloads\laharz_py_example\mtrain_example\fill
full path dir :C:\Users\cmoser\Downloads\laharz_py_example\mtrain_example\dir
full path flac :C:\Users\cmoser\Downloads\laharz_py_example\mtrain_example\flac
full path str :C:\Users\cmoser\Downloads\laharz_py_example\mtrain_example\str
_________ Creating DEM Array _________
_________ Get NumPyArray Dimensions _________
Shape is: (986, 1251) (rows, colums)
Number of rows is: 986
Number of columns is: 1251
_________ Set Window Boundaries _________
wXmin (TOP): 0
wXmax (BOTTOM): 985
wYmin (LEFT): 0
wYmax (RIGHT): 1250
_________ Convert Textfiles to Arrays _________
Volume List is: [1000.0, 3000.0, 10000.0, 300000.0]
Points entered: [[587737.0, 5204869.0], [579305.0, 5196801.0], [577930.0, 5191581.0]]
Cross Section Area List is: [20.0, 42.0, 93.0, 896.0]
Planimetric Area List is: [2000.0, 4160.0, 9283.0, 89628.0]
_________ Creating startpts_g _________
Failed script laharzdistalzones.py...
File "D:\Programs\ArcGIS\Desktop10.4\ArcToolbox\Toolboxes\laharz_py_example\laharz_py\distal_inundation.py", line 1621, in <module>
main(argv[1], argv[2], argv[3], argv[4], argv[5], argv[6])
File "D:\Programs\ArcGIS\Desktop10.4\ArcToolbox\Toolboxes\laharz_py_example\laharz_py\distal_inundation.py", line 1169, in main
tmpStartPoints = ExtractByPoints(Input_surface_raster,startCoordsList,"INSIDE")
File "d:\programs\arcgis\desktop10.4\arcpy\arcpy\sa\Functions.py", line 1409, in ExtractByPoints
extraction_area)
File "d:\programs\arcgis\desktop10.4\arcpy\arcpy\sa\Utils.py", line 53, in swapper
result = wrapper(*args, **kwargs)
File "d:\programs\arcgis\desktop10.4\arcpy\arcpy\sa\Functions.py", line 1405, in Wrapper
return _wrapToolRaster(u"ExtractByPoints_sa", unicode(result.getOutput(0)))
AttributeError: 'unicode' object has no attribute 'getOutput'
Failed to execute (laharzdistalzones.py).
Failed ta Wed Mar 21 17:19:09 2018 (Elapsed Time: 1.06 seconds)
Outcomes
