Edit existing data in Survey123 Form from Collector using custom url?
4376
11
03-21-2018 08:42 PM
SuddhaGraves
Hi all,
When you launch Survey123 from Collector using the custom url, can you make the form load with existing data vs creating a new record?  When I launch Survey123 using the custom url, it appears to be creating a new record.  However, I am looking to create the record in Collector, but then have the capability to edit the existing record using Survey123.  Any help/suggestions would be appreciated.
Regards,
Suddha Graves
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Suddha,
Currently there isn't a way to open Survey123 in edit mode via URL.
by Anonymous User
Not applicable
Has this functionality be added yet?
JamesTedrick
Hi Jeff,
This capability has not yet been added.
MapMagicians
Hi, I'am also looking this functionality to edit existing inbox data via URL scheme. I read all related threads and found many users periodically asking this since 2017. Bit strange this still not implemented.
MikailaBell
Sorry, I meant to reply to your question. Check out this post -- the web form will open to a record, called by objectID, and allow you to edit. https://community.esri.com/groups/survey123/blog/2019/05/24/survey123-tricks-of-the-trade-editing-re...
AustinCanty1
Hi James,
Has this been added yet? See other replies below that seem to indicate it should be possible.
MikailaBell
The only way to open Survey123 to an editable record is with the web form.
BenjaminSperry1
Hi, I was looking at the documentation and it seems like this should be possible now, although I haven't been able to get it to work.
The URL I used (that didn't work):
arcgis-survey123://?itemID=<the survey item ID>&q:GlobalID=175cdb66-c666-48c4-85c5-c7aa96609724
(I also tried it with the object id)
Has this functionality been added yet? If so how do I get it to work?
Alex_Reid
I'm wondering the same thing, I tried this yesterday and got it to open the record in edit mode but it still created a new feature when Submit was pressed.
