Creating Vector Tile cache using Arcmap
1803
6
03-21-2018 12:55 AM
MANESK
Is it possible to create a vector tile cache using ArcGIS Desktop 10.5!!
DanPatterson_Retired
are you talking about a feature cache?
MANESK
Yes Dan. I've a feature class of a continent. I need to publish as a web map so that it should render fast.
XanderBakker
Esri Esteemed Contributor
If you have ArcMap and you are on maintenance you also have access to ArcGIS Pro. As far as I can see the creation of vector tiles is not possible using ArcMap. You will have to use ArcGIS Pro: Author a map for vector tile creation—ArcGIS Pro | ArcGIS Desktop
MANESK
Thanks Xander. I'll try it.
GISSupport3
Occasional Contributor III
I'm guessing a vector tile cache is unable to be viewed via ArcMap / ArcEngine?
from Xander's link, even the alternatives would limit you
Alternatively, you can use the Create Vector Tile Package tool. This tool will generate a complete vector tile package, a .vtpk file from a map or a basemap. You can then share and use the vector tiles in ArcGIS Online or ArcGIS Enterprise.
