Lady_Jane
VBA red text - 9.2 to 9.3.1
Discussion created by Lady_Jane on Jan 31, 2011
Latest reply on Feb 1, 2011 by rwelikal
Hi everyone,
I used a piece of code when I was using ArcGIS 9.2 to split lines into segments of no less than a given length.
I am now using 9.3.1 and there is one line in the code that is giving me trouble. This line:
For lInFld = 0 To pInRow.Fields.FieldCount â?? 1
from the code below shows up in red, and when I run the code it causes a syntax error.
Any help would be appreciated
Private Sub Proportion_Click()
'Divides a line feature class into segments no less than a specified amount
'Source: â??http://forums.esri.com/Thread.asp?c=93&f=986&t=264945&mc=1#msgid815131
' Make sure that the layer is an editable, projected, polyline, with features selected
Dim pEditor As IEditor
Set pEditor = Application.FindExtensionByName("ESRI Object Editor")
If pEditor.EditState <> esriStateEditing Then
    MsgBox "start editing first"
Exit Sub
End If
Dim pEL As IEditLayers
Set pEL = pEditor
If pEL.CurrentLayer.FeatureClass.ShapeType <> esriGeometryPolyline Then
    MsgBox "target layer must be polylines"
Exit Sub
End If
Dim pFSel As IFeatureSelection
Set pFSel = pEL.CurrentLayer
If pFSel.SelectionSet.Count = 0 Then
    MsgBox "select some " & pEL.CurrentLayer.Name & " features first"
Exit Sub
End If
If Not TypeOf pEditor.Map.SpatialReference Is IProjectedCoordinateSystem Then
    MsgBox ("set a projection first")
Exit Sub
End If
'get the user-defined minimum segment length
Dim dInterval As Double
dInterval = InputBox("Enter minimum segment length in meters", "Segment Length", 250)
' Set up a query to select features greater than the minimum segment length
Dim pQueryF As IQueryFilter
Set pQueryF = New QueryFilter
pQueryF.SubFields = "Length"
pQueryF.WhereClause = "Length > " & dInterval
'pEditor.StartOperation
Dim pFCur As IFeatureCursor
pFSel.SelectionSet.Search pQueryF, False, pFCur
Dim pFeat As IFeature
Set pFeat = pFCur.NextFeature
Do Until pFeat Is Nothing
    Dim pPolyline As IPolyline
    Set pPolyline = pFeat.ShapeCopy
    pPolyline.Project pEditor.Map.SpatialReference
    Dim l As Long
    Dim Max As Integer
    Max = Int(pPolyline.Length / dInterval)
    For l = 0 To Max
        Dim pOutCurve As ICurve
        pPolyline.GetSubcurve (l - 1) / Max, l / Max, True, pOutCurve
        Debug.Print pOutCurve.Length
        pOutCurve.Project GetSR(pEL.CurrentLayer.FeatureClass)
        If l = 0 Then
            Set pFeat.Shape = pOutCurve
            pFeat.Store
        Else
            Dim pNewFeat As IFeature
            Set pNewFeat = pEL.CurrentLayer.FeatureClass.CreateFeature
            CopyFields pFeat, pNewFeat
            Set pNewFeat.Shape = pOutCurve
            pNewFeat.Store
            pFSel.Add pNewFeat
        End If
    Next l
    'Show something in status bar
    Dim pStatus As IStatusBar
    Set pStatus = Application.StatusBar
    pStatus.Message(0) = "Processing " & pOutCurve.Length
Loop
pEditor.StopOperation "split at " & dInterval
MsgBox ("Finished!  Don't forget to save your edits!")
End Sub
Sub CopyFields(pInRow As IRow, pOutRow As IRow)
Dim lInFld As Long
For lInFld = 0 To pInRow.Fields.FieldCount â?? 1  <--- This line causes trouble!
    Dim lOutFld As Long
    lOutFld = pOutRow.Fields.FindField(pInRow.Fields.Field(lInFld).Name)
    If lOutFld > -1 Then
        If pInRow.Fields.Field(lInFld).Editable Then
            If pInRow.Fields.Field(lInFld).Type <> esriFieldTypeGeometry Then
                pOutRow.Value(lOutFld) = pInRow.Value(lInFld)
            End If
        End If
    End If
Next lInFld
End Sub
Function GetSR(pGDS As IGeoDataset) As ISpatialReference
Set GetSR = pGDS.SpatialReference
End Function
Outcomes
