AnsweredAssumed Answered
Can't convert ESRI Metadata to ISO19139
Question asked by roelandtn on Mar 20, 2018
I extracted metadata from an SDE using arcpy.
I tried to convert it to ISO19139 using arcpy and the script below.
If I load the raw metadata in GeoNetwork it tells me unknownSchema. I tried to convert it using arcpy.ESRITranslator_conversion() and ESRI_ISO2ISO19139.xml translator. In that case, GeoNetwork says BadSchema.
I'm a bit stuck. Any idea how to fix that ? Am I missing something ?
Best regards,
Nicolas Roelandt
Here is the script  used :
#!/usr/bin/env python
# -*- coding: utf8 -*-
import os, sys, arcpy
rep_projet = ur"D:/Projets/PP/GeoNetWork/test/"
source_md_format_iso = rep_projet + "ADM_chef_lieu_formatESRI.xml"
rep_install = ur"C:/Program Files (x86)/ArcGIS/Desktop10.5/Metadata"
translator =  os.path.join(rep_install, u"Translator", u"ESRI_ISO2ISO19139.xml")
rep_sortie = rep_projet + "sorties_HTS_10.5"
arcpy.ESRITranslator_conversion(source=source_md_format_iso,\
                                translator=translator,\
                                output=os.path.join(rep_sortie, u"ADM_chef_lieu_ESRI2ISO19139.xml"),\
                                logfile=os.path.join(rep_sortie, u"log.log"))
Outcomes
