AnsweredAssumed Answered
Python script tool converts "Data File" output type to GPString
Question asked by peterlen on Mar 19, 2018
Latest reply on Mar 19, 2018 by peterlen
I am using ArcGIS 10.4.  I have a Python script tool where my tool's output type is set to "Data File" when I add it to a toolbox.  When I publish it and I look at the tool's service endpont, I see that  the output data type is set to GPString.  When I run the tool from the endpoint via Submit Job, the tool runs fine but the output value is blank.  As a test, I changed the output data type to String in the toolbox and then re-published the tool.  As expected, the output data type is listed as GPString at the service endpoint .  When I run the tool via Submit Job, the output value is a file system path to the data file (a ZIP file).  Not sure why when I define the output data type as a "Data File", that it changes it to GPString after publishing and then does not contain the expected value when the tool is run as GP Service.  The goal in this is actually have a derived URL to that output file be sent as the output.  That is what happens when using a Python Toolbox (.pyt) and setting the output parameter to "GPDateFile".  When running the tool from the Python Toolbox via ArcCatalog, the output is simply the system file path, but when the tool is run via the GP Service, the output is converted by ArcGIS to a URL to the file.  Due to other issues with publishing my Python Toolbox, I needed to publish the same tool as a script tool that I added to a toolbox.  I expected the results to be the same, but for some reason they are not the same.  I am not sure if the output value is empty in the case of the "Data File" output type of the script tool because ArcGIS has some issue with generating a valid URL.  Does anyone have any insight into what may be happening?  Thanks - Peter
Outcomes
