I have some custom tools in .NET that we use in ArcMap 10.2 that I am hoping I can get rid of by using templates in ArcPro. I am following the instructions here: Create a preset template—ArcGIS Pro | ArcGIS Desktop
What I want to do is create the mainline connection (a point snapping to the watermain), the hydrant service line (line) and the hydrant (point snapping to the end of the service line) using a 'Preset Template from Selected Features'. Following the instructions above, I am using an existing feature, select all of the features in the order of digitizing, and then go to 'New' - 'Preset Template from Selected Features' but that option is grayed out. The only option available to me is 'Group Template' which doesn't seem to do what I want.
Any help is appreciated.
So it appears that using the "Group Template" feature will do what I want. The process of creating the template is a bit finicky, but I was able finally create a Hydrant with a lateral line and a service connection, which I can snap to an existing watermain, and orient it in anyway I want. A much better solution than the 'Preset Template from Selected Features'
Just thought I would post in case anyone else was trying to figure it out too.
