Vertical Exaggeration
1057
03-20-2018 04:32 AM
nasserhinai
Hi Guyes,
Could I find ( Vertical Exaggeration ) in cityEngine ?
It's in ArcScene  in Scene layer properties . ( see attachment )
Luiz_AmadeuCoutinho
Occasional Contributor III
Could you explain why you need the vertical exageration on CityEngine?
There are others options to represent the same on CE
nasserhinai
Hi Luiz,
Vertical Exaggeration give me a chance to display more deference between tops and bottoms in Satellite imegry .
But in CE when I add the Satellite imegry on top of DEM it look like a flat area which is not normal .
I hope you could nuderstand what I mean .
LR
Select the elevation layer and change the code in the bottom box, like attr elevation = map_01(pow(brightness,2), 0.0, 100.0) + elevationDelta.
nasserhinai
it's work .
Thank you
