AnsweredAssumed Answered
Territory Design wizard returns 0 territories
Question asked by PaulDavis on Mar 14, 2018
Latest reply on Mar 19, 2018 by PaulDavis
Any idea why the parameters below return a blank table with no territories from the territory design wizard?
Thanks in advance for your help!
Territory layer name: March_14_2018_3
Creation time: 2018/03/14, 17:16:42
Last modification time: 2018/03/14, 17:44:58
Last modified with: Territory Design Build# 10.6.0.920
Comments:
Territory layer datasource path: c:\my output data\projects\usa\territories\march_14_2018_3
Alignment Layer:
Alignment Layer name: March_14_2018_3.ZIP Codes
Alignment Layer dataset path: C:\ArcGIS\Business Analyst\US_2017\Data\Demographic Data\ZIPCodes_zp_esri.bds
Network dataset: C:\ArcGIS\Business Analyst\US_2017\Data\Streets Data\NorthAmerica.gdb\Routing\Routing_ND
Barrier layers:
C:\McAllister\Data\Simplified_Layers.gdb\Franchise_PDR_50
C:\McAllister\Data\Simplified_Layers.gdb\FRanchise_PDES_50
Territory Design Extent defined: Yes
Set Extent to: Business Analyst Study Area
Study Area name: USA
Territory Design Extent calculation method: Polygon centroid contained within extent
Number of territory levels in hierarchy: 1
Level name: Territories
Number of territories in level: 0
Territories creation type: With Summary Data
Manual correction: No
Territory creating options:
Territories naming: Assign default territory names
Initial territories number: 0
Number of territories to be created: Optimal
Use capacity value(s) for territories: Yes
Capacity variable(s):
2017 Total Population:
Minimum: 500000.00
Maximum: 800000.00
Preference: 100%
Fill extent automatically: Yes
Override constraint parameters: Yes
Clustering options:
Territory locations will be calculated using: Spatial locations only
Density influence for locating territories: 50%
Balance territories: No
Distance type: Network Analyst (time): c:\arcgis\business analyst\us_2017\data\streets data\northamerica.gdb\routing\routing_nd - TravelTime
Distance units: Minutes
Maximum distance that a territory is away from its seed point or center: 120
Minimum distance from territory center: Not specified
Minimum distance between a territory centers: Not specified
Compactness: 75%
Territory center allocation method: Center of density
Territory centers will be calculated using: Spatial locations only
Territories were automatically balanced: No
Current level parameters:
Minimum: 500000.00
Maximum: 800000.00
Preference: 100%
Outcomes
