AnsweredAssumed Answered
The value type is incompatible with the field type. [Shape__Area]
Question asked by HWMontreux on Mar 16, 2018
I'm collecting data on the field with the Collector app in a polygon feature layer.
When I get back at the office, I synchronize my data and when I'm trying to export my feature layer into a shapefile, I get this error message: "The value type is incompatible with the field type. [Shape__Area]." As you can see in one of the screenshots, there is no field type called "Shape_Area" in my data.
I'm having this problem only with polygon feature layer, not with points or lines.
The only workaround I found is to export it as a geodatabase file, open it in ArcGIS Desktop and then save it as a shapefile, but I should be able to export it directly as a shapefile, right?
Here are a few screenshots, let me know if you need anything else.
Thansk in advance for your answer.
Best regards
Joaquim
Outcomes
