Bookmark Widget (v2.7) Selected Color
536
8
03-14-2018 09:59 AM
JasonStanton__GISP
I am trying to add a background color to the selected bookmark in the v2.7 widget.  In the v2.4 widget I added the following code to "common.css", but now this is not working.
      .jimu-img-node.jimu-state-selected{
           background-color: #86b186;
Does anyone have any ideas?
Jason
RobertScheitlin__GISP
Jason,
  In 2.7 Card style bookmarks there is no selected class that is added on click of a bookmark. You will have to add two css rules to the common.css and code to the CustomBookmarks.js and WebmapBookmarks.js files
Css rules:
.jimu-img-node.jimu-float-leading.clearFix.selected{
  padding-top: 5px;
.jimu-img-node.jimu-float-leading.clearFix{
  padding-top: 5px;
WebmapBookmarks.js:
define([
  'dojo/Evented',
  'dojo/_base/declare',
  'dojo/_base/lang',
  'dojo/_base/html',
  'dojo/_base/array',
  'dojo/on',
  'esri/SpatialReference',
  'jimu/BaseWidget',
  'dijit/_TemplatedMixin',
  './utils',
  'dojo/query'
  function (Evented, declare, lang, html, array, on, SpatialReference,
    BaseWidget, _TemplatedMixin, utils, query) {
      _onBookmarkClick: function (bookmark) {
        query('.jimu-img-node.jimu-float-leading.clearFix.selected').forEach(function (node) {
          html.removeClass(node, 'selected');
        html.addClass(bookmark.itemNode.domNode, 'selected');
CustomBookmarks.js
define([
  'dojo/Evented',
  'dojo/_base/lang',
  'dojo/_base/html',
  'dojo/_base/array',
  'dojo/on',
  'dojo/sniff',
  'jimu/BaseWidget',
  './utils',
  './ItemNode',
  'jimu/dijit/ImageChooser',
  'dojo/query'
  function (Evented, declare, lang, html, array, on, has,
    SpatialReference, BaseWidget, _TemplatedMixin, utils,
    ItemNode, ImageChooser, query) {
      _onNodeBoxClick: function (bookmark) {
Jason,
Css rules:
  padding-top: 5px;
  padding-top: 5px;
WebmapBookmarks.js:
define([
  'dojo/Evented',
  'dojo/_base/lang',
  'dojo/_base/html',
  'dojo/_base/array',
  'dojo/on',
  'jimu/BaseWidget',
  './utils',
  'dojo/query'
CustomBookmarks.js
define([
  'dojo/Evented',
  'dojo/_base/lang',
  'dojo/_base/html',
  'dojo/_base/array',
  'dojo/on',
  'dojo/sniff',
  'jimu/BaseWidget',
  './utils',
  './ItemNode',
  'dojo/query'
JasonStanton__GISP
Thanks for the help Robert!  I really appreciate it!
Jason
JasonStanton__GISP
Robert,
I just realized that how I added/replaced the code in CustomBookmarks.js and WebmapBookmarks.js caused the bookmark widget to not work.  I am adding 'dojo/query' under define and query after function.  I am not sure if I should be strictly adding the _onBookmarkClick and _onNodeBoxClick code (and if so where), or if I am replacing current code (and exactly what code I am replacing).  I tired a few variations which all failed.
Can you please help me?
Jason,
   You are just adding the dojo/query require to each file and then adding the new
code to the _onNodeBoxClick functions.
JasonStanton__GISP
I SWEAR I tried that, but I must not have been using my brain when I did.  It works fine now.  THANK YOU!
JasonStanton__GISP
Robert,
Any idea how to update the 2.13 version to change the background color on the selected bookmark?
Jason
Jason,
   Not much has changed they only added an additional module to the define array...
CustomBookmarks.js
define([
  'dojo/Evented',
  'dojo/_base/lang',
  'dojo/_base/html',
  'dojo/_base/array',
  'dojo/on',
  'dojo/sniff',
  'jimu/BaseWidget',
  './utils',
  './ItemNode',
  'libs/Sortable',
  'dojo/query'
    ItemNode, ImageChooser, Sortable, query) {
WebmapBookmarks.js
define([
  'dojo/Evented',
  'dojo/_base/lang',
  'dojo/_base/html',
  'dojo/_base/array',
  'dojo/on',
  'jimu/BaseWidget',
  './utils',
  'libs/Sortable',
  'dojo/query'
    BaseWidget, _TemplatedMixin, utils, Sortable, query) {
JasonStanton__GISP
Thanks!  Not sure what I was doing wrong, but it works now!
