Show/Hide widget for a group of users
634
03-12-2018 11:22 AM
WarleyMendes
Hi, I would like to know if there is a way to show or hide a widget for a specific user group.
I have been building a Portal Application and I'd like to display the edit widget for some user that are on activity directory group and hide for others users.
Is it possible?
Warley Mendes
RobertBorchert
Frequent Contributor III
You will need separate web apps.
That is a functionality I would like to see however.
DerekLaw
Esri Esteemed Contributor
Hi Warley,
> I have been building a Portal Application and I'd like to display the edit widget for some user that are on activity directory group and hide for others users. ... Is it possible?
Confirming that hiding/showing certain widgets in Web AppBuilder for ArcGIS based on Windows Active Directory memberships in Portal is not possible.
I am not sure if you want to restrict the ability to create web apps that have the Edit widget, or if you just want to restrict editing functionality in general. May I suggest: you could assign Portal members to different Portal roles: one with edit privileges and one without.
Hope this helps,
