We use both ArcMap and Google Earth Pro at work. I'm trying to be able to use the identify tool in Arc to then copy the lat/lon and paste into GEP. Is there ANY way to get the Arc to display it without having to switch the numbers around in GEP to get to the correct location? It's not very user friendly. I understand where ESRI is coming from but not why I can't find a way to customize it.
TIA
You can't change Arc*, and apparently Google is rubbing against the grain, but you can code it, if you don't want to copy/paste them one at a time AND you have lots to enter
As a simple one-off example
now picture dozens and the brackets removed in the output
