Hi
I'm currently evaluating the ArcGIS SDK on Android for a new Application. On one device I get the following exception when zooming in and out a lot and fast. Less than a second later the App crashes.
E/AndroidRuntime: FATAL EXCEPTION: Thread-29745 Process: foo.bar.baz, PID: 15552 com.esri.arcgisruntime.ArcGISRuntimeException: Invalid argument at com.esri.arcgisruntime.internal.jni.CoreRequest.nativeGetCanceled(Native Method) at com.esri.arcgisruntime.internal.jni.CoreRequest.h(SourceFile:208) at com.esri.arcgisruntime.internal.i.b$4.run(SourceFile:232) at com.esri.arcgisruntime.internal.a.g.b(SourceFile:45) at com.esri.arcgisruntime.internal.a.e.a(SourceFile:115) at com.esri.arcgisruntime.internal.a.c.done(SourceFile:44) at java.util.concurrent.FutureTask.finishCompletion(FutureTask.java:355) at java.util.concurrent.FutureTask.set(FutureTask.java:204) at java.util.concurrent.FutureTask.run(FutureTask.java:245) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587) at java.lang.Thread.run(Thread.java:818)
The device where this is happening is a Samsung Galaxy Tab A (SM-T280) and the application currently shows some ImageTiledLayer instances (as basemap and as overlay). The Runtime used is 100.2.1.
Did anybody already had the same problem and found a solution or is is possibly a bug in the library?
Sam
