I do not have a geopoint question in my survey (management did not want it).
However I did set the default location (in the Map Settings in Survey123 Connect) to desired coordinates... sometimes the point features in the service are at the appropriate location sometimes they are off the coast of Africa.... (I am located in Florida, USA) and sometimes they are at different locations (close to the default but a mile or so away)
Why are some of the points being placed there and some are not, and how can I fix this? should I force the geopoint question? I figured by adding the default coordinates if a location could not be established via networktivity the default location would be used?
Hi Joe,
The default location setting in Connect is used to set the default location of the geopoint map and inbox map (map extent and zoom settings). It is not used to set the default x,y of the actual geopoint question and geometry submitted to a feature service.
Even when you have not added a geopoint question to your survey, a geometry will be collected and submitted as it is a required attribute of a feature service. If location services are disabled, device in offline mode or no valid location is available, the device will return 0,0 and therefore the geometry will be saved as 0,0 which is off the coast of Africa.
If a location is obtained by the device and passed to the app (via wifi, gps, 3g etc), the geopoint question will be updated with the device location and the geometry saved representing the location where the survey was taken. This will happen whether you have or do not have a geopoint question in your survey. By displaying the geopoint question it allows the user to modify it.
Is there a reason why you do not want to collect the location of where the survey was taken, and use the same location for all surveys?
Phil.
