I'm experimenting with this new ArcGIS Pro 2.0+ that became available at my workplace (currently using ArcMap), and I'm experiencing some inconsistencies with datasets brought in via query layers from our SQL Server (currently '08 server. Tried w/ a '16 server and had same issues).
Some datasets seem to work just fine (selecting / "identifying" / searching), and some datasets erroneously return incorrect records when I "identify" them with the new "Explore" button. Example: I "identify" a utility pole in front of our building, which I know has a name of "POLE-X", but the "identify/explore" window returns back "POLE-W". If I "identify" that pole again it may return another pole, "POLE-Z", or sometimes no object attributes at all.
Has anybody encountered odd behavior like this before?
Hi Alex. Please make sure that you're on Pro 2.1.2 which is the current version and check your setup against ArcGIS Pro 2.1 system requirements—ArcGIS Pro | ArcGIS Desktop
Supported database management systems—Help | ArcGIS Desktop
Where is the data coming from? In the attachment, is the S9-207 a label coming from the POLE field?
Again, make sure you're on the current version and that you meet the system requirements/supported databases and follow up after that. Thanks!
