color ramp does not stretch
861
03-05-2018 12:56 PM
HelgaGomes
I am having yet another problem with my  interpolated plots. I want to keep one range of values for parameter A for 5 figures from 5 years so that  I can compare them. This is because the range in values changes with year and I want to show this interannual difference. But if I change the High-Low values in Layer properties it defaults to the High and Low of the data in question. That is it stretches the bar for the data in question and does not pay heed to my input values of high and low. You can see that in the data attached where I created two ranges and the figure did not change at all. I wonder if there is some setting I am not changing. This is pretty trivial in other software but I have wasted so much time with ArcMap with nothing to show.
the other thing is that I know this forum has retired but when i start my question and try to change the Publish Location I dont seem to see anything relevant like ArcMap etc.
Thanks a lot.
Helga
DanPatterson_Retired
https://community.esri.com/community/gis/mapping?sr=search&searchId=77be88de-24d2-4612-aa64-5b8e839b...‌ would be a good place.  There is no specific ArcMap place.
If you are working in ArcMap, you can create a colour ramp that applies to your possible range of values, then save it as a layer file (*.lyr in arcmap, *.lyrx in PRO), then you 'import' the symbology using that layer to apply it to your other layers.
HelgaGomes
OK guy I figured it out after i posted this question. In the Layers menu i have to change Type to Minimum and Maximum and then give my Min and Max. for Values but all I did was change the labels.
thanks
Helga
