Have Operations Dashboard only pull data from last submitted form in Survey123
477
03-04-2018 08:44 AM
PatrickHannan1
We're trying to keep track of some basic inventory and I have created a Survey123 data form to track it. At the end of each day, the form is filled out with the remaining amount of inventory left. I created gauges in the Operations Dashboard to show how much inventory is left and that is measured against what we have when fully stocked. I can't find a way to have it show just the data from the most recently submitted form. For now I just have it showing "Yesterdays" submitted data. If I set it as "Todays" data, it displays "No Data Available". I've tried combining the "is before" and "is after" but I just can't seem to get it to display what I need, for the time frame I need it. Since you have only a few options for the "Statistic", I use the "Sum" and I try to have it filter so I just see the most recent data, not summed data from previous days. Is there a solution to just showing the most current data that I'm just blindly missing?
JamesTedrick
Esri Esteemed Contributor
Hi Patrick,
Apologies for the delay.  It sounds like you might be affected by a data refreshing issue in ArcGIS Online- it will be addressed in the next ArcGIS Online release.
