Buffer Geometry of a Dropdown Selection
4252
10
03-01-2018 10:31 AM
ClintonLunn
Hello all,
I am trying to buffer a polygon of a dropdown selection. I am hoping somebody can point me where I am going wrong.
var TRSSelect = dom.byId("selectTownshipPanel");
on(TRSSelect, "input", function(e) {
  var type =  e.target.value;
  var task = new QueryTask({
    url: panelurl + "2"
  var params = new Query({
    where: "trs = '" + type + "'",
    returnGeometry: true
  task.execute(params)
  .then(function(response) {
    console.log(response.features["0"].geometry);
    console.log(response.features[0].geometry);
    console.log(response.features[0].geometry + " TRS response FEATURES");
    console.log(response.features["0"].geometry + " TRS response FEATURES");
    buffer = geometryEngine.geodesicBuffer(response.features["0"].geometry, 100, "feet", false);
    console.log(typeof buffer);
    console.log("buffer completed");
    bufferLayer.add(new Graphic({
      geometry: buffer,
      symbol: polySym
My output for this code is:
It is able to retrieve the geometry, but will not execute the buffer (does not lot to console "buffer completed") and add to the graphic layer.
I have isolated this to the buffer because if I pass in the response.features[0].geometry, the resulting geometry can be added to my graphic layer illustrated here:
    //buffer = geometryEngine.GeodesicBuffer(response.features["0"].geometry, 100, "feet", false);
      geometry: response.features[0].geometry,
      symbol: polySym
Graphic layer is displayed now when passing in just geometry of response features:
MelitaKennedy
Esri Notable Contributor
It's very old. My records show both 102113 (3785) / 102100 (3857) as being added at 9.3.0, but I think that's wrong and 102100 was added at 9.3.1. Anyway, the switch to 102100 / 3857 occurred a lot of releases ago. EPSG:3857 was added by EPSG in 2008.
Other software often can't use the Esri or EPSG definition of 102100 / 3857 because they both use a variant of the "Mercator" map projection. So a software that has the regular Mercator might use EPSG:3785 which uses a sphere-based GCS instead to force the usage of a major auxiliary sphere (radius = semimajor axis).
The functions might be failing because the input/output GCS are actually different. There is a transformation, 15973, which converts between the two GCS.
JohnGrayson
Esri Alum
...check the spelling of the geometryEngine method... geometryEngine.geodesicBuffer
ClintonLunn
John,
While I do feel very silly for that little typo, that did not make it work. I will update the code in my question to reflect that correction. Thank you!
KenBuja
MVP Esteemed Contributor
What is the spatial reference of the geometry you're attempting to buffer? Is it WGS-84 or Web Mercator? If not, you'll have to use the GeometryService buffer method.
ClintonLunn
Ken, the spatial reference is listed as:
Spatial Reference: 102113 (3785)
This seems as though it is a deprecated form of Web Mercator?
KenBuja
Yes, according to this post from Melita Kennedy‌, Esri's guru on projections and spatial references. Although, according to the isWebMercator method, 102113 would return True.
ClintonLunn
Ken,
Forgive my ignorance, but does this deprecated spatial reference now mean that the geometryEngine will not work in this case?
In which case, I'd either have to use the GeometryService or change my layer to conform to this spatial reference requirement, correct?
Thank you,
Clinton
KenBuja
I don't know, unfortunately.
Is the wkid 3785 correct? That comes up as something else: Popular Visualisation CRS / Mercator: EPSG Projection -- Spatial Reference
ClintonLunn
Yes, that is correct. I was puzzled when I searched that wkid too.
MelitaKennedy
