Maplex engine refuses to display labels on some views using an orthographic projection when zoomed out past a certain point (1:58,157,528 in this case). In particular this seems to mostly occur with Australia or the Far East as the center of the view. The labels will show once zoomed in a little if I pan the view toward the top of the screen or once I zoom in even more if I do not pan the view at all. If I pan back down without changing the zoom the labels disappear.
- Visibility Range is set to none for both In beyond and Out beyond.
- The labels do NOT show as unplaced labels when selecting View Unplaced.
- Selecting Unplaced labels, Never remove has no effect.
- Weights and Priorities are all at the defaults and changing them has no effect at the problem zoom level.
- Turning off all other layers also has no effect.
- The labels immediately display when changing to the Standard labeling engine.
What am I missing?
If you have something that can be reproduced, if possible create a Project or Map Package of it and send it off to your local ESRI distributor including a bug report.
I have done that myself for a few regressions that occured in Maplex when ESRI made some pretty big changes and added new functionality to Maplex going from ArcGIS for Desktop 10.2.2 to 10.3. Since then, the reported issues got fixed (at least finally almost completely in ArcGIS for Desktop 10.6 and Pro 2.1.1).
